Bodyglove BT headset
2 replies · 1,458 views · Started 02 March 2004
I have just gone one of these and it seems Ok but can't get the voice dialing or any voice commands to work. Is this correct or am I doing something wrong.
For nokia phones, you normally need to pair it differently than you would for most other phones.
Take a look in the manual and look for an alternate pairing procedure.
On the jabras for instance you would pair the phone by holding the on button for 7 seconds, but for nokia phones and to get the voice dialing feature you need to hold down the volume up and on button for 7 seconds.
Probably simular for your headset too.
Good luck
Will
thanks fro the info, I will give that a try. Both manuals are useless and theres nothing on the website either. Do you get full voice dialling/commands on the jabra headsets?
