P800 Mirror Plug
4 replies · 7,179 views · Started 02 March 2004
Hi All,
Work gave a me a new P800 for work use and in the box was a mirror plug..
In the little packet had a a few serial numbers
Mirror Plug
13042-SXA-109 3078
(REV D) Week 3 25
There is no instructions on how and where to insert the plug?
Anybody know what to do?
Anthony
It is a plug for a SE T610. Just checked my packaging and the serial no. etc matched.
I have not found any way to mount a T610 mirror plug on a P800.
I think it was more than likely a packaging error, the mirror plug jobby slots into a hole on the back of the t610, so you can see yourself if you wanna take a piccy of yourself. There is absolutely no way you'd manage to get it on a P800, unless you jabbed it into the antenna port with some blu-tac.
you can however, get a 3 cm diameter drill, and gently start drilling just by the camera lens, this should create a small crater good enough for the blu tack 😉
