Hi
On my 6600 if someone sends me a WAV file via Bluetooth/Infared, it won't play correctly.
It will play the first second or so then cut off. These are only tiny files, i.e 2 seconds long.
The 6600 is capable of playing WAV's isn't it????
Hi
Sussed it.
Thanks for all your help. The response was overwhelming.
yes it can play wav files and you are very welcome 😊
Can someone help me with this same problem, i to have wav files that cut out after a second. Thanks for your help.
Jonathan
I was trying to play WAVS that people had bluetoothed over to me from their handsets, i.e SPV or Erricson and I don't think a standard WAV is compatible.
I am now using PC Suite that came with my 6600 and that automatically converts the WAVS to a format the phone can read correctly.
I hope this helps.
44Khz 16 bit mono PCM is pretty standard to me,maybe the SPV doesn't use standard wavs.
