MMS Problem.
5 replies · 1,906 views · Started 03 March 2004
Hi.
I have this problem which is when i want to create an mms message and click on that option nothing happens, I cant get into the multimedia messaging box.
I'm having the same problem. I have a nokia 6600 and when i try to send a multimedia message it doesn't respond. I also can't open the multimedia messages i saved on my phone. Please help!!!
azzy wrote:Hi.
Check you have the right settings.... Menu/messaging/options/settings/multimedia and check the settings and access point in use.
If not got to network providers web site and send them to your phone as sms and "save as settings" then retry. 😊
I have been able to use mms until today and just now when I try to create an mms it doesnt do anything, i have all the right settings because its worked before.
please tell me theres a quick fix cos i dont want to format my phone again 😞
CageUK wrote:I have been able to use mms until today and just now when I try to create an mms it doesnt do anything, i have all the right settings because its worked before.
also i cant access the multi media message settings anymore. I have a tendancy to fiddle on with my phone with apps and stuff but ive done nothing out of the ordinary that would affect the mms system.
