Beamed files
1 replies · 1,796 views · Started 03 March 2004
I have a P800 with the Philips Camcoder installed. When I beam an MP4 file it only launches in the Philip Camcorder and not the default Pocket Video application. Does anyone know how to view/save the file in Pocket Video.
I could move the MP4 file from the 'Beamed' folder and place it in the regular 'Video' folder using a file explorer. Does anyone know where the 'Beamed' files are saved in P800?
a long as you have Philips Camcoder installed, it'll be your default browser for MP4 files, so it'll launch automativally when you tab on any .mp4 file.
to open then in Pocket video, you've got to save the files in Media Files\video then open Pocket Video software and choose to open the mp4 file from there!
for beamed files, it's usually in the C:\system\mail folder but it's not an easy issue to handle them from that folder, but the easiest would be by using FielSearch software (download it from here , it's free) then you can search for the files you've beamed and move them to your favourate folder with a click!
