wht should i do when my phone says "start up failed contact the retailer"
if i go to retailer wht amount he will take.
Just delete your post and the problem will go away!😉
You should follow this guide:
http://www.allaboutsymbian.com/forum/showthread.php?s=&threadid=17507
-kris
I HAV NOT SAID ANYTHING WRONG TO U THEN WHY U??????
JUST TELL ME
Most likely,you will need to do what the phone says,contact the retailer.
hi! i just bought my 6630 last month. whenever i start my phone, "phone start up failed, contact retailer" appears on the screen. i've tried many times the "3 key combination: dial; star; #3" but it wont start the formatting. can you help me?
[QUOTE=dimebag]hi! i just bought my 3660 last month. whenever i start my phone, "phone start up failed, contact retailer" appears on the screen. i've tried many times but it wont start the formatting. can you help me??????????
I had found a solution from somewhere, switch off,take MMC out phone and switch it on with the two keys pressed (unreleased till phone starts)
and
key
try if it works... once worked for me then i quickly took backup of everything, depend on first startup its possiblephone may not start second time through trick.
