Disappearing Themes
2 replies · 2,153 views · Started 04 March 2004
Can anyone help with this? When I click on Themes nothing happens and it returns to the main menu. It worked okay until now. I thought maybe the memory was full and deleted a few things but that hasn't helped. I turned it off and on even taken the MMC and chip out and put them back but still can�t open Themes. Everything else sees to work.
Thanks in advance for any help,
Micheal
SymbianUser wrote:Can anyone help with this? When I click on Themes nothing happens and it returns to the main menu. It worked okay until now. I thought maybe the memory was full and deleted a few things but that hasn't helped. I turned it off and on even taken the MMC and chip out and put them back but still can�t open Themes. Everything else sees to work.
Micheal
Dude,
I got the same problem on my 6600!!!
How did you fix it?
well,i dunno what lead to this,i think it is because that theme is protected or something like that,it will happen if u use mangothemes...u can use psiloc extended profile pro to change the theme or just delete the theme you're using now to be able to access theme,hope this help 😊
