Help with Wap and GPRS on Orange
4 replies · 2,403 views · Started 10 September 2002
could someone on Orange with a 7650 please post the details of WAP and GPRS settings,
I just cant get it to work, tried a brethe one and that worked OK, but I am with orange and would like to use that 😊
Many thanks 😊
Jason.
Orange UK GSM WAP settings:
Data bearer: GSM Data
Dial Up number: +447973100500
Username: orange
Prompt password: no
Password: Multimedia
Authentication: normal
Gateway IP: 192.168.71.35
Home: http://orange.multimedia/
Data call type: ISDN v.110
Max data speed: 9600
Security: off
Session mode: permanent
GPRS settings are the same (tho some details are not needed) except the Data bearer should be "GPRS" and Access Point Name shoudl be "orangewap".
For MMS settings change the Access Point Name to "orangemms"
hope this helps, this was all taken from the manual I received from Orange with my 7650.
Hmm, having just said that, the usernames appear to be slightly different on my actual phone settings which were updates from the orange update SMS.
On my phone the there is no GPRS username (though still a password), and the GSM and MMS usernames have Orange capitalised. So try both and see which (or presumably both) work.
the gprs works with no username, and set as APN orangewap,
I dont think I put a password, the wap works with the settings u gave
UN Orange
PW Multimedia
cant get the mms to work, but then again I have not got it enabled from O as they dont know I have a 7650 😊
