I've Downloaded the " Series 60 Theme Studio " but while im installing it give me an error saying " The installer can not run in your configuration, It will quit now " i think that the problem is the xp because in the readme txt says something about just for win2k i think that is not fault of my system coz i got a Amd Athlon xp 2400+ 512 mb DDR of ram so i think that maybe is the xp or some other configuration if u can help me please, Thank You
got a lil problem
Right click on the file and then click properties. Then from there click the compatibility tab and then check the box in the compatibilty mode box and choose win2k. This should now let you use the program. Hope that helps.
Thanks Joker it worked 😊
