With me was the same!! but i dont have the memorie full, i have a lot of free mem. I finish delete some fotos in the phone, and then i restart the phone but it dosen�t turn on. But im luky because i have 15 days to return the phone if sonthing is wrong. they give me another brand new!!
cant restart to!!
...have had a similar problem, taking the battery out to completely discharge the phone did the trick for me.
Guys, i don't know how this is in other country's but here in germany if you are a nokia phone owner and best have registered your phone via club nokia you can just go to one of the Nokia Stores next to you and let em fix that asap, i mean there in the shop, takes about an hour. This is a service they have here, the upgrade/repair your phone as long as it is only software. And this bootup problem because of full flash memory should be no problem.
Now that is interesting!
Anybody in the UK got anything to say to ellaborate on this?
In Vienna its the same - only that it didnt take an hour but one day to upgrade my phone's software because they had a lot to do 😊
but i hear,that Noki(t)a say,that the 76 is a level 3-service.
That means,they will send all the Devices back 2 Finnland.
hope,that its not true,cause mi wanna get my F*** Dust out of my display...
GreetZ from the swiss S�mi
only soft-updates are made!!
i�ve updated my phone in a nokia shop but is still not starting.
only way to swap the phone and all the data (photos are lost !!) are lost
Does a software update include Bluetooth version upgrade? I read in this forum that a Nokia service center can make the 7650 bloototh headset compat.
Don't recall anybody saying the Bluetooth audio profile is added by doing an upgrade. The latest firmware seems to the 3.16 which is the one inside the Orange 7650's.
Quite unlikely it would though as Nokia specifically say that one of the differences between the 3650 and the 7650 is that Bluetooth Audio is supported on the 3650.
[quote="tman"]Don't recall anybody saying the Bluetooth audio profile is added by doing an upgrade. The latest firmware seems to the 3.16 which is the one inside the Orange 7650's.
Quite unlikely it would though as Nokia specifically say that one of the differences between the 3650 and the 7650 is that Bluetooth Audio is supported on the 3650.[/quote]
Read clems post:
http://allabouter6.com/phpBB2/viewtopic.php?t=2188
