Ewan Spence and FreEPOC (and the whole OPL Development team!) announce the availability of Event Core for UIQ OPL. Event Core is a program that does absolutely nothing! It's strength lies in the fact that packed in the zip file is the OPL source code that illustrates how everything works.
Event Core - OPL Skeleton App for UIQ Coding
Thanks Ewan and everybody that has helped to create EventCore on UIQ.
Running EventCore on the UIQ emulator, I have got :
Error in Core\Init
Invalid arguments
The culprit is the line 147 of "Core.opl" (I created "Core.OPL" by importing "Core.TPL"😉 :
gSETWIN 0,0,0,0
a simple workaround is to use
gSETWIN 0,0,1,1
I suppose gSETWIN does not like to have a lot of zeros 😉
Maybe this problem does not arise on a real UIQ phone.
Roberto
gSETWIN 0,0,0,0 fine on the phone, must be somethign in the Emulator. Good fix there Roberto
Why can I only activate the menu with the wheel ? Is it not possible to activate by stick ??? Have I to edit somewhere i the code ?
Have a read of the Menu text file in the Docs folder. The menu handling is not fully working under UIQ. There is a workaround with the push in button.
