i just did an upgrade to the latest F/w version and now i cannot browse the folders via Explorer it says "Not Connected" but on the systray i got the P900 icon which mean it's connected also i can do sync backup and others
but on the explorer it just says "Not Connected"
anybody experienced this problem and solutions ??
First thx for that ... 😊
read that bfore and not solve the problem
but mine kinda different
on the Systray it say connected and i got the little p900 on the systray too, hence i can do Sync backup and etc
but when i open windows explorer and clicked the P900 icon which usually has the Memory Stick and Phone Memory folders shows "Not Connected"
did an uninstall and upgrade to the new PC suite version and still not working 😕
I had that problem a few times. I just played with different USB ports and phone connection link. the problem dissapeased. i also tried restarting the phone and pc. good luck
i tried everything uninstalling firewall and reinstall the pc suite
but still no go ...
what is strange is it works bfore for maybe a month just yesterday it started this ...
so today i install it on different machine and it works
i dunno what is the problem cos two of my systems got quite same applications installed
Something must be different. Find out what it is.
What did you do between when it last worked and when you first noticed it doesn't work any longer?
That's the period where something happened and if you don't remember what it was (what you or someone else did), it isn't easy for outsiders that weren't there to figure it out either. 😉
The only sollution i see is to reinstall windows. I do it every 5-6 months. after that period it starts to crash a lot. sometimes i just want to kill Bill Gates ....................... 😊
