i have try to install the proggie sx1 cd on my computer to sync the phone with outlook the program is installing verry well no problems
but there is no conexion tru them to the phone
before i hat sl45 that one was verry good no problems also outlook was perfect
can i use a other proggie to sync and put contacts in and agenda apointments ????
outlook
check your firmware version *#06# if you have version 5 upgrade to version 6 and this should fix the sync problem. You can can get it from www.my-siemens.com
