Can P900 Use MPF-10 Blitz?
5 replies · 2,921 views · Started 08 March 2004
it does not work as it does on the z600.
also the sos function is not supported. you need manually to push the light button on the flash to use it.
i can use it on the t68 ( sos only )
Ok, i'll use it manually then. Thanks for reply.
its not that bright for a cam flash if u ask me....😞 i bought one..😞
novi... did u try it on the z600? does the flash light up much brighter on the p900 or just the same? Cause i read the manual saying that in z600 u can push the switch 2x quickly the push it again it will light much brighter...
Hmmmm... Ihope Se can develop an installation file for the p800 and p900 .... I wish 😃
I've bougth one also. It's way to weak flash/light. Objects must be like 30 to 50 cm from light, or it fade away. I also hope P900 can get some software written that will make the flash able to rise the 'flash' with x2. The dokument that fol the flash says push button fast 2 times to x2 the flash power. But i can't get it to do that with my P900.
Anyone else tested this?
i've tested it and it ain't working😞
