Hi folks,
I really need some help with my 7650 and my infrared connection. I think the MA620 usb infrared device installs fine but when i install the nokia suite the mrouter program only shows infrared connection. It doesn't say anything else or show any COM ports. If i select it and connect my phone it says it is connected but the damn nokia suite software doesn't think it is. Windows will also recognise it as a nokia 7650 and install a "standard IR link modem" in the device manger to confuse me even further.
I have tried it on a friends comp with XP home (i have XP pro) and it works fine. The mrouter program shows cable and unknown on the COM ports as well as an infrared connection.
Can anyone help me????
