Hi guys,
I have downloaded the FSCaller applet available at Siemens' website. It allows you to display a photo of the caller on your screen.
I am very disappointed in the quality of the photo display, especially in full-screen mode. Perhaps my pictures are the wrong size and are being zoomed and stretched all to hell.
Would anyone know what the supposed "full-screen" image size would be in pixels?
thanks
elfer
my fs caller is perfect with the pigtures so it is the qality of your pigtures
Hence my question about pixel dimensions....
you have to make your photo's in the full screen mode so the resolution of 480*640 (or vice versa) is being used instead of the smaller resolutions of the thumbnail and standard mode. You'll see it will sharpen the photo in FScaller far more! I'm afraid this IS the limit or maybe you can shoot photo's on your digital camera with a very high resolution, decrease the size of the picture, upload it to your phone as .jpg file and add that one to your contact(s). Never done this myself but something tells me the result will be very good.
I'm using a PowerBook and when I use iSync to synchronize my contacts with the SX1 it ports the mini-portriats that mail.app uses into the phone. Hence, when I make a call there is a small image of the person I am calling. In the contacts section of the SX1, however, the image that I select does not override that small pic. So I'm wondering if anyone knows where those smaller pics are stored and how to overwrite them with something better quality? (the mac pics are 64X64 and look pretty bad)
i have also other problems with fs caller 3.0 full
1- i activete fs caller but after i turned off and then on my phone again it is deactivated. how i can make it to be active when phone starts..
2- sometimes fs caller makes my phone ring different ringtone then i selected. anyone has idea???
There is a bug in this program.
SymbianWare send a "autoexecdaemon60.sis" for correct it.
A+
can someone give the full version of full screen caller??
or someone can give me the key gen of fs caller 3.01??
thank a lot..........
[email]removed[/email] and banned.
I couldn't find the applet in Siemens.com
