Importing Favorites
4 replies · 1,762 views · Started 10 March 2004
i don't know if this is the most ideal way, but if you right click on the favorite, copy the URL, and then just use something like remote p900 and paste the url into your p900
Ta for the reply, I've got about 500 favorites though, could take a while! I was hopeing there would be somthing to do it automaticaly.
ahh, found a quick way, on your internet explorer, just click on the bluetooth icon in the shortcut things (toolbar), and then select the device, and it'll send that page to your phone and it will save as a favorite 😉
Ta, I think I've found an easier way (for me anyway) though. You need your own hosting for this, but if you go to the 'file' then 'export' menu in IE it gives you an option to export your Favorites. You then upload this to your webspace, when you go to that page you can navigate to where you want. Not ideal, but quick and easy.
