Check this out!
You record a voice memo, the let this program animate it ready to send via MMS.
It send it via MMS as a *.3GP Video!!
There is a demo available on the website.
Check this out!
i can't get it to work. Badger could you please tell me how to get it going??
I've been watching the development of this for a while now.
THIS IS AWSOME!! 😊
I think it's brilliant 😊
Get it NOW!!
Will
Heres some pix.
hey will wats the spot reader?
I can't get it to work either 😞
It won't start up.
I can create the message, and play it back, but when sending using 'Vodafone MMS' or 'Vodafone GPRS' as an access point (I have tried both), it fails. The error I get with the MMS point is :
'Message Failed, Multimedia message not accepted by message centre'. The error I get with the GPRS access point is that it just gets tagged with a 'Resend @ **:**' in my outbox.
So...Does anyone have any clues. I would really like to get this app working and part with my tenner @ Handango 😊
I reckon the Bush Peron is best for the facial animations.
I have tested this on both O2 & Orange and it worked fine, it could be due to the size of the MMS. Thinking about it Voda may have a smaller max MMS size than of the other networks.
If you want the video, create it and send it so it sits in the outbox, then use a file manager to extract the *.3gp from the mail folder.
I wonder if we (voda) users could have the option of recording a 10 sec clip instead?
@ Badger, are you in anyway affiliated with this product?
If so, could you look into it, or let me know either way so I can contact the authors myself. Other than that, us voda users are buggered. I'll call voda and see what their limit is.
Cheers
Voda limit is about 35k, everyone else is 100k.
Voda users have trouble sending full size pictures too.
Thou if you phone them they don't admit it.
You'd think they would lift the restrction now that video MMSing is more widespread..
Strange.
Would be good if we had the option to send via bluetooth or e-mail, or even a simple save option would do the trick.
Will
I am with o2.I can send facewave on my 6600 but I cannot receive it myself.I sent to myself.I get the gprs flashing and mms tone as if im receiving a mms message but nothing appears.
Whats happening?
Ok,
I have called Vodafone, and spoke to a very helpful girl.
The limit we have is 30KB. There could be a way around it, like Will has pointed out. If we could save the file, we could then email it as there is no limit on the size of data concerning email.
So, I suppose we have to talk to the peeps who have made the software to see if they can put in some extra options.
I'll try and send an email off later...work permitting.
Cheers
Yakkob, unfortunally not!
I will have to purchase it like everyone else!!
