I have wiped my nokia 9210 and application card. As a result I can't sync with my PC cos all the programs have been wiped.
How do I get around this problem.
Many thanks for any replies,
John.
John.
First off, restore your backup!!
This will put the majority of your info back on to your device.
Then re-sync.
Badger,
Thanks for your reply.
Sadly I dont have any backups (silly me!!).
I guess the query I really have is would any of the programs I wiped be required to allow syncing with my PC or is this functionality written in the phones firmware (the most logical place I would of thought).
Thanks again,
John.
It you cannot lose anything by installing the "Device Data *.sis" from you CD. Or Nokia.com
http://www.nokia.com/cda1/0,1080,1913,00.html
Do this by connecting to Pc and pressing "Tools > Install Device Software" from the top menu.
Wirelessly posted (Nokia6600/1.0 (3.42.1) SymbianOS/7.0s Series60/2.0 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Yeah this should work :s if not ... Pepsi.... Oops i meant ask 4 more 😊
great, another one for the books 😊 one do you intend to sync if your commi's all wiped out 😕
