My 3650 stopped writing alphabets, only numerics
8 replies · 4,043 views · Started 11 March 2004
Hi!
Please help me on this..
My 3650 mobile was working well for 2 months and suddenly, it stopped writing alphabtes.. it only writes numerics.. 1,2,3.. in contacts, messages...
What happend? I remember pressing on some buttons in a stupid way then this happened..
Any sugesstions?
Did you also install WildPalm's WildSkinz? It causes problems like this on every other Series 60 phone except perhaps the 7650 which it was written for (or maybe even on it). If so, disable it, uninstall it, restart phone.
Don't uninstall without first disabling it. If you do, you have to reinstall it, enabled it, restart, then disable, uninstall again, restart.
In general, to switch between number and text mode, press the # for a couple of seconds (when in any text entry field). The indicator will switch from "123" to "abc". A short press of the key cycles between "Abc.", "ABC", "abc", etc.
Either that or you could backup your information as well as some apps onto your Pc, do a factory reset and try to punch in alphabets. If it still don't work you oughta get a firmware upgrade or some check up from the place you bought your phone from. Hope this helps! 😮
Originally posted by carcomptoy
Have you tried holding down the # button until it shows a change in input type?
You didn't my reply above from a week ago where this was already noted/suggested? 😉
Yeah, I know, I read it AFTER I posted my entry...oh, well, hopefully, the person will get the message by now!
_My mates,
_In case, don't be panic. It's not too complicated. You can handle this.
_Run some file managing program (i'd prefer eFileManager), don't forget letting it show system folder (with eFileManager, for example).
_Get into c:\system then simply delete system.ini file.
_Restart your stubborn phone. Then, you'll see.
Regards,
Anh Tuan
Press the little pencil button on the left to open the menu that controls the setting for Number mode / Alfanumeric mode.
kharwa3 wrote:Hi!
Any sugesstions?
