Backup restore on MacX
1 replies · 1,625 views · Started 12 March 2004
Unfortunately not, unless you just mean contacts and calenders, for which you can use iSync.
What you can do is use Virtual PC running Win 98se or above to install and run the SE software. It will even update firmware via the web, though this does take some time.
