Few questions if anyone has the answers i'd be really gratefull.
I've got a P800 with charger and a 128mb Duo stick. I've not got the docking station but I have got a bluetooth dongle. I want to be able to copy stuff from the PC directly to the 128mb card but I can't find an option at the moment. I have to transfer stuff to the internal memory using bluetooth then move it over to the external memory. This is ok but some files are too big so I can't get them on the 128mb card. 😞 Also, how do you browse the phone in an explorer type interface so I can browse and delete directories etc?
Thanks, it's pretty confusing at the moment 😕
Wirelessly posted (SE P800: SonyEricssonP900/R102 Profile/MIDP-2.0 Configuration/CLDC-1.0 UP.Link/5.1.1a)
Have a search for ecpocware file manager.
get a memory stick card reader, they're only like 5 quid from ebuyer.co.uk
Why don't you just use the bundled PC software; PC-Suite, it lets you copy stuff straight to the mem stick. It works with a BT connection just the same as a cable connection.
thats what i do too. i install games/apps on my phone via the pc suite. i also copy my music files by pasting it directly in the memory stick using also the pc suite.
