is there such a software for 92xx that can dial-up to win95/98 dial-up server?
if there's more than one out there, what do you recommend?
thanks. 😉
thanks. 😉
The dialler software that comes with the 9210 should do the trick for you. I have gotten it to work with Win2K and NT4, only without the callback.
TANKERx -- thanks. can u let me know what exact dialler application that came with the 9210? 😊
[quote="whiplash"]TANKERx -- thanks. can u let me know what exact dialler application that came with the 9210? 😊[/quote]
I configured my 9210 to dial up a Micro$oft server by configuring in the 'Internet Access' component of the Control Panel, just as I would a normal internet connection.
thanks again! I will try it.
/me takes hat-off
very quick reply! good day!! :P
