Smartmovie released --> watch divx on your P900
6 replies · 6,911 views · Started 14 March 2004
Ive just got this app, but when i try to send an avi file to my memory stick, it tells me that this type of file is not allowed. Ive got the app installed on my phone and the avi codec.
Originally posted by nk8
excellant quality with divx mpeg 4 compression, no lagging or anything,
care to share the settings? I had xvid on mine and i did notice some "out of sync" with the sound. Did you use mpeg on the software then download the codec for smartmovie?
I've got the same problem. In fact you are not allowed to download the avi file in the "Video" folder. But in the "document" folder that works ! And Smartmovie can find itself all video file on your P900
Another way to get around that is to rename the file from file.avi to file.mp4, then copy it into the Video folder of your MS Duo, then use the file manager to rename it back to file.avi
