I want to get online. I need to get online.....I need a Computer...😃 Please remember me to post this wav... Is great....
Now to the problem.
I want to connect my 9210 with nokia 6600 using E-internet GPRS.
Even if i tried with two dial strings *99# and *99***1# does not seem to work.
Any advice?
Cheers
Wirelessly posted (Nokia6600/1.0 (3.42.1) SymbianOS/7.0s Series60/2.0 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Com'on guys. No answer yet ?
The string dial is used on the GRPS phone, not on your Nokia 92xx.
Extend Internet on Nokia 92xx need you to select a GPRS infrared modem. I have created on for the Nokia 7650, with :
Initialization:
Init string : ATZ
Advanced :
Flow control : Hardware
DSR/DTR : On
DCD : On
Try it and tell me if it works.
Roberto
Gush 😊 i hate technology sometimes. It is not working. 😞 damn i was sure i will make it with your help. May be psiloc will answer my mails 😞
Try to use 57600 or 38400 bps on the GPRS infrared modem configuration of Extended Internet.
When you not working, what you get ? Any error messages ?
Good luck,
Roberto
