screen saver
7 replies · 2,871 views · Started 14 March 2004
new from here can somebody halp how to find a great screen saver program for nokia 6600.. thanks in advance
Just to inform you that the battery life of your phone will dicrease a lot by using this screen saver.
You will need to charge it everyday. 😃
no it is not really like u said:
only if u put some animadet .gif 4 screensaver it will drain the batterie.
but with clock8big one, analog,etc) thre is no drain at all.
ive test it out very long:
it is the same standby with or without the clock.
(its only a task that ones activate at start)
Well, I tried powerlock with the clock as screen saver and it drained the battery alot. Without Powerlock the battery lasts about 1.5 days longer.
Harry
😮 i have installed pisloc screen saver 1.81 it works and runs correctly for like 5 mins and the default nokia screen kicks in n over rides it :con?
how can i uninstall the default nokia saver or turn it off
i have fexplorer installed if that helps to remove it
THX Ch3f
You can't uninstall the inbuilt screensaver, it is part of the operating system rom. I had this problem, I found that you ha you play around with the 'time out' setting in the control panel and your theme settings. I can't remember the correct solution but I only had it for the trial period.
