About service (o2,t-mobile etc)
4 replies · 1,688 views · Started 14 March 2004
Hi everyone, 😊
😞 Please advice me.
When im work at basement of building, my mob is no service (like ariel(antena), when im at ground, its working service, u know i mean?
i use my P900 with Orange is crap! its always up and down! but other like o2, t-mobile which best at basement will working service?
hope u understand?
cheers
Dunko9
uhhh, basements aren't the best place to use your cell phone, which will be why your signal fluctuates a lot, phone masts are built above ground level, and as networks build their masts in different places, no-one can really say which network will give you the best signal at your work, when you log into the network, you don't connect to just one mast, which makes it even harder to determine
ok thanks for explain.
That because im work at basement all the time, if any happened like emergency!!! that why i need it!!
oh well never mind. 😞
im hope in the future the mast will be at basement hahaha! 😃
cheers
Dunko9
hey, have you tried the coathanger trick? get 87 coat hangers from TK MaXX, and undo them all, and make them all into one line, as straight as possible, apart from a tiny right angled bend at one end, and plug that into the top of your phone (drill might be needed),
