Hey people. Can somebody help me how to upload MP3 from PC to phone. I'm using IR to transfer it yet, the file on inbox remains to be unrecognized. help!!!!
On MP3Go uploading
use ultramp3 its better. it will reconise the mp3 anywhere you put it on the phone
Use PC suite to put it straight into your music folder, then add it to you playlist from within the app.
Will
i'm sorry but my pc usite won't work. i've done the settings right but still it can't connect. is there another way to transfer mp3 files from my computer to my phone? help again
Send them as email attachments.
Send them directly via Bluetooth or infrared.
Put them on a web or WAP site for download.
Use a PC-based MMC reader.
Where can I download Ultramp3?
It gets mentioned a lot, but I cannot find a download site depite searching around.
press the button at the top of the screen that says 'shop'
then search for 'ultramp3'
Best
Will
thanks - I did find it shortly after I posted. I was then too distracted installing and playing to re-post to say I had found it. Thanks for following up! Sorry for being lazy...
