I've converted a few of my Grandpirx clips with the multimedia Pro, and boy they are truly sensational quality! 😃 😃 😃 😃 😃 😃
Why the hell Nokia didn't includ this with the disk I'II never know! :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil:
Sure there sensational quality, but serious size's.
I just converted a 6 minute F1 Clip which was 5.3mb on normal compression conversion!
Now I've converted one at the highest quality, and its 125.35MB!
WOW.
I'II think i'ii leave all my clips as they are thankyou!
:roll: :roll:
use quality 3 or 4 that's good enough really trust me 😊
10fps
and the a slightly reduced size.
Thanks 😉 😉 😉
I'II try that setting tomorrow. 😃 😃 😃
With reduced size I mean (you have to go low to get the excellent 10fps):
124*(the best you can get) this is multiplied at the device which gives you 248*(something) which is almost full size but because of the speed looks very good.
For quality I use 5 most of the time, but for really good stuff I use 3
Thanks again, I'Ii keep u updated on my progress tomorrow, when I will be converting my clips again.
