My SX1 is pretty wierd.
I have though about reinstalling the whole symbian system. How do I do this???? Is there a image somewhere I can download for this.
Reinstalling the SX1
You might be able to do so by typing in
*#7370#
This works on nokia symbian phones... not sure about siemens.
Anyhow check the manual.. it should be possible.
You need to enter a security code afterwards, still.
Which is 12345
Oz
hi i am looking to reinstal the system on my n-gage i typed in the above code and it asked if i wanted to reinstall and i pressed yes then it asked for the lock code and i typed in the 12345 and got code error, where do i find out this code ??
mrbobhaton wrote:hi i am looking to reinstal the system on my n-gage i typed in the above code and it asked if i wanted to reinstall and i pressed yes then it asked for the lock code and i typed in the 12345 and got code error, where do i find out this code ??
12345 is the default code if you changed it or someone changed it then that person is your only hope. 😃
