It is very nice let's go to see what is it?
Music and video playback and streaming
Internet TCP/IP with IPv4 and IPv6* over (E)GPRS or (HS)CSD
Opera browser supports HTML and XHTML pages
Integrated VGA camera
FM radio
Email (SMTP, POP3, IMAP4)
MMS (including SMIL)
Integrated handsfree & voice recorder
Bluetooth technology (including audio)
Personal Information Management: calendar, contacts, tasks, and more
Word, Sheet, and Presentation Viewer; Word & Sheet converter
Flight mode
Offline mode
Touch screen
MP3 player
*Note that this services require network support
Full Specifications
Tri-Band Operation
GSM 900/1800/1900
Automatic switching between bands
Size
Weight: 183 g
Dimensions: 165 cc, 133.7 x 79.5 x ~21.6 mm
Display and User Interface
High-resolution LCD display
Series 90 UI with touch screen
Display size: 640 x 320 pixels
65,536 colors
Touch-screen, pen-based input with stylus
On-screen keyboard
Handwriting recognition
Physical keys:
Scroll and select key (scroll up, down, left, right, select)
Back/Cancel
Home (Apps key)
Menu key
2 application-specific keys
Send key
End/Exit key
Voice key
Power key
Audio/Visual Media Features
Camera: 640 x 480 pixel resolution; 2 x digital zoom
RealPlayer: Playback and stream RealMedia (video and audio) and 3GPP-compliant content (H.263 and MPEG-4)
Music: supports MP3, AAC, RealAudio 7 and 8, WAV, MIDI, and AMR-NB file types. Keep your sounds organized with Nokia Audio Manager (NAM)
Images: supports JPEG, GIF, BMP, PNG, and animated GIF images
Sketch: Edit images (crop, zoom, rotate, and flip) and draw your own. Add images to contacts or send them (via MMS, email or Bluetooth).
Stereo FM radio
Memory Functions
20 - 25 MB of internal memory available for contacts, text messages, multimedia messages, ringing tones, images, video clips, personal information management, and applications
64 MB Memory Card provided in the sales package
Additional memory units available (up to 128 MB)
Phone Features
PIM: Contacts, extensive calendar, Mobile Wallet 2.0, calculator
Office applications: Word, Sheet, and Presentation Viewer
Flight mode: all radio-related activities turned off
Offline mode: Use the MP3 player, FM radio, AAC, PIM, and Bluetooth without a SIM card
Messaging
Multimedia messaging: Multimedia messaging (MMS) with compatible devices; send and receive messages containing text, images, audio, and video.
Email: Access your work and private email accounts; supports SMTP, POP3, and IMAP4 protocols
Text messaging: create, send, edit, and receive text messages (SMS).
Games
Downloadable Java� MIDP 2.0 and Symbian games
Java� Applications
Downloadable Java� MIDP 2.0 applications
Ringing Tones
Use MP3, AAC or AMR-NB files as ringing tones
Up to 24 polyphonic ringing tones
24 ringing tones preset, all removable
Wireless Connectivity
Pop-Port� interface
Connect phone wirelessly to a compatible phone or a compatible PC
Over-the-air ringing tones, settings and messages (for Web access point, Web bookmarks, and SyncML)
Remote OTA synchronization with SyncML; local synchronization with PC using PC Suite
Browsing
HTML and XHTML with Opera browser
Downloadable plugins
OMA mDRM - forward lock for content protection
Wallet: convenient online use and storage of your numbers and passwords
Data Transfer
EDGE*
GPRS* (multislot class 10)
E-GPRS* (multislot class 4 (3+1))
HSCSD (High-Speed Circuit-Switched Data)*
Circuit-switched data
TCP/IP*
*Note that these services require network support.
Call Management
Click-to-talk: Easy dialing with the touch screen interface
Contacts: Advanced contacts database with support for multiple phone and email details per entry; also supports thumbnail pictures and groups
Speed dialing
Logs: Keeps lists of your dialed, received, and missed calls
Automatic redial
Supports Fixed Dialing Number, which allows calls only to predefined numbers
Conference call (up to 5 participants)
Power Management
Battery Talk time Standby time Charging
BP-5L (1300 mAh LiPo) up to 3-4 h up to 10-11 days up to 2 h
Variation in operation times will occur depending on SIM card, network settings and usage. Talk time is increased by up to 30% if Half Rate is active, and reduced by 5% if Enhanced Full Rate is active.
Software
PC Suite
http://nokia.com/nokia/0,8764,47551,00.html
