Ok I've used the record function before to record of the radio and it has allowed me to record for as long as I want. But recently when I try to record off the radio it will only record about 10-13sec's of audio before it stops recording. I've also had this experience when I try to record from the audio cable. Before you say it yes I have plenty of space on my MMC and also in phone memory (not that this matters cuz its saved directly to MMC) basically what I'm asking is there a cure? and also has anyone else experienced this???
Recording Radio To N-gage
cant think of anything that cud be causing it but a hard reset and mmc format should sort any problems out
Same problem here dude. I'm actually trying with the original card, to verify if it's actually a card issue, or a recorder issue. After all, I can still record normal audio without problems.
Same problem. Already tested. Still the same problem. Maybe it's a card issue.
Hard Reset??? You mean totally format the phone? O yeah I'm using the org nokia card so I don't think its a card issue. Seems really strange it used to work fine and now its suddenly stopped working.
Ok now this is really strange. As I just made that last post I decided to try it again and now its perfect worknig again recording as I type got 2mins so far so it seems all good. Strange why it stopped working werid. O well its fixed now so its good.
sometimes angels come and touches the devices 😊 i don't have any clue about how they work again sometimes 😃
For me it's still not working. Maybe my N-Gage doesn't like the radios I listen to... 😃
Yea format the fone. *#7370#. make sure the battery is full and a charger is connected before formating it though 😃
From past experiences with just about all the smartphones available, a hard reset or a software upgrade always seems to olve any problems that arise.
SAbz
I'll have to make a firmware upgrade, I've heard that a 4.something firmware was out. Don't remember where, though.
