Nokia 6600 problem?
6 replies · 2,475 views · Started 19 March 2004
Guys ,when i enter my PIN code and it says ''code accepted'', then there is a small intro video from NOKIA with 2 hands holding each other . The prob is that the sound stops without finishing !! Any ideas why that happens ??
Because of software you installed 😊
If memory serves me right some things called recogs start up right then and they stop the sound.
The truth is REALIS that i 've installed the bluetooth software on my NOKIA 6600 +several progs that i uninstalled them later on..What should i do ?(As u may understand i can't uninstall the bluetooth software...)
What bluetooth software have you installed as the 6600 has this built in already? Or am i missing something here....
He means bluetooth software on pc (i pressume).
I wouldnt worry about the sound mate,many people have this issue and unless you want to keep your phone as nokia intended with no additional apps,then there aint nothing you can do,its no big deal is it?
When the phone is switched on it searches for add on apps etc and this causes the prob!😊
Yes elton i mean the bluetooth software on pc.
There isn't a big prob gyus i Know..But if u pay almost 500 euros for a mobile you expect to be reliable.Even though i guess where the prob lays..(The add on software we install are not -possibly- Nokia approved )
