Problem with Handy Clock
12 replies · 3,296 views · Started 12 September 2002
I have the trial of this program installed, and my clock keeps moving one hour back for me. If this was already posted I'm sorry but I didn't read it. Did anyone have this problem, and how can i solve it. The autoupdate off won't help. Thanks
Mine keeps on going a half hour forward ... and I have yet to get to the bottom of why it is doing it. I might not be anything to do with HandyClock app ... most likely a bug in the underlying sw of the device
Hello All,
Sorry for so many problems with Handy Clock. The reason is bugs in the operating system. Anyway, we are working on the next version of Handy Clock at the moment and will try to fix all the problems there.
Meantime you can try Handy Clock 2.0 beta version here:
http://www.epocware.com/beta/files/HandyClockDemo.sis
Many problems already fixed in this version.
Also please write all thoughts and detailed descriptions of your problems to [email protected]. All active beta testers will receive Handy Clock 2.0 full version for free.
Thank you in advance!
Br, Andrey Scherbakov
Epocware
I had a similar problem - my clock went a half hour forward and I couldn't work out why it kept jumping after I reset it several times.
Just now I noticed that the laptop I synchronise with was also out by a half hour. So I tried a little experiment, I set the clock on the lap top to be out by 1.5 hours and then synchronised the phone ... and hey presto, suddenly the phone had its clock set incorrectly by .... you guessed it, 1.5 hours.
So the problem is not so much a bug - just an undocumented feature (those clever programmers). It sets itself to whatever time is set on the PC. So fix your PC time clock properly and your phone should be set right too.
yeah,this could be also one reason.
but ive got the same troubel with the first beta,and at this time,i already now this feature from a german board.
But even the bug was exist.
(it has nothing 2 do with the HC,its a feature of Nokia himself:it also works without HC.)
now with the V 2 it wporks stabil.
ThanX 2 epocware 4 there great support 😃
S�mi
