Starting apps automatically on boot-up
4 replies · 2,921 views · Started 21 March 2004
My issue with autoexec program:
- If you restart phone manually my scheduled programs start correctly.
- If the battery dies and then you switch back on, none of the programs start.
My battery dying is my most common restart, so its a massive problem to the software! What can I do? Are there any other programs like Autoexec?
thankyou for the sugestion, I will get a copy and try it
does it solve the issue of not working on a forced reboot from battery dying?
Sorry, don't know the answer to that, but when my 6600 has done a reboot for no reason, all the startup apps are running.
I have AUTOSTART 1,02 and it works fine. If I take battery out the applications are started on reboot.
Active desktop is CooL application but it slows down the telephone and I also don't like everything on my nice desktop 😉
