does p800 have quickshare...and how does it work?? saw on the website that if you like something you can share it using quickshare...so wondering if anyone has ever used it before....
quickshare
The P800 doesn't officially have QuickShare. But, to be honest, all it means is that, within the imaging application, you have the option to directly send as e-mail, or MMS or whatever. It then pulls up your address book. Select the person you want to send it to and off you go. So, technically, you can take and send a picutre in about 6 clicks.
I think you can do this with the P800 anyway. So, quickShare isn't a program, or international standard or anything like that. It's just a label SE have started putting on the box of certain products that allow you to send pictures from within the imaging apps, rather that having to go to the messaging app and then attach the image. The P800 came out before "QuickShare" so the label isn't on the box.
sounds reasonable enough bro..thanks
