To Do List + Alarm
3 replies · 2,048 views · Started 22 March 2004
Guys,
I've just bought 6600 a week ago.
What I was wondering is, is there a way of entering a To-Do list or Task (or this kind of things) and specify a Reminder (with Alarm) with it. I know you can do an Appointment instead, but that's not exactly what I want.
If we can't do it with the default Calendar app, is there any 3rd PArty app that does it ?
Thanks a lot,
Chris
I would suggest to use microsoft outlook, enter your note with a reminder which you can set whenever you want, day & time, and then synchronize your phone via PC suite. It will ring the alarm when the note will be due.
Cheers,
You can create a New meeting entry in default calendar, it will give you the alarm when the time is due. Rather if u create new entry as memo, the alarm will not work.
regds.
I also has same thoughts with Mahadewa, if there is a third party soft can be installed in the mobile phone to add remider to TO DO list or notpad will be great.
