ultramp3 after rescan no mp3 found?
3 replies · 1,738 views · Started 22 March 2004
The subject says it all:
I installed ultramp3 (trial). But after using the rescan-function for several times no mp3 at all where found!!?
I downloaded the trial from three difrent links (in case there meyed be a broken file or a not updated file) but nothing changed!
Is anyone familiar with the problem. I installed ultramp3 on the mmc and on the phone itself. Nothing changed.
greetings
Ailic
well u need to copy the mp3 files by using the pc suite. make sure that u change the setting of the converter. don't convert it to wav , save it under the digital folder scan it and u will get the songs.
u can download from this link . tonnes of applications .
enjoy 😊
i have same problem to.
i have install ultramp3 but i cannot change playlist so i can't play song
can any one give me explenation
