PC bt connection to mobile
5 replies · 1,665 views · Started 23 March 2004
I have know BT on my PC. I have been able to send files and programs to my mobile Nokia 6600, but when it comes to connect to PC Suite I can't. Don't know waht to do, also how can I connect to the internet using BT and my mobile? Thanks in advance,
If this is the same as the problem I had (can send files to phone but cant send anything to computer) then I couldn't actually find any relevent help on the forums.
/-|R
u would need to install your BT driver before installing the PC Suite.
This was the main problem for most pple using PC Suite with NK 6600.
It solved my connection problem.
Search for it in the forum. It has been mentioned before.
I don't even use PC suite. I have the latest BT drivers installed. I can't send anything from my phone to my PC.
Any ideas...
/-|R
Any ideas...
/-|R
1. Is your BT dongle working? Any indicator that is able to transmit and receive properly?
2. Your BT on your phone on?
3. What sort of file you trying to send?
4. What is the brand of your BT dongle?
