Sync multiple contact databases to Outlook?
1 replies · 4,916 views · Started 15 November 2001
Hi all. Is it possible to sync different contact databases to Outlook? I have nearly 1000 contacts and it slows the 9210 down terribly. I would like to put most of the contacts, that I don't need all the time, into a separate contacts db on the phone. But I would like to sync everything to Outlook. I guess it would make sense to use an Outlook category for this, but can't see any easy way to do that with pc suite. Hints? Tips? Clues?
Here is the one possible hint
1.Create second Contacts folder in Outlook.
2. Create 2nd contacts DB in 9210
3. Create 2nd "Contacts Sync task" in PC Suite and do not define default folders for both databases in this task. Use "Select Communicator Contacts" dropdown menu for selecting your 2nd Communicator Database
4. Click to change button in "Contacts sync option" menu. Use Outlook 97/98/2000 tab for selecting your newly created Outlook Contacts forlder.
I hope this will solve your problem.
Ozgur Altun
