3gp and mp4 encoder
6 replies · 24,544 views · Started 24 March 2004
Just thought you all might be interested in a new piece of software i found that converts video files (and audio i think) into 3gp and mp4.
The software is called mpegable x4 live and a demo version of the software is available from here
Ive played around with the settings and so far i think its the best 3gp encoder ive used yet. The picture quality seems loads better than that of video created with Nokia's MMC or PV PLayer. But maybe thats just my opinion.
Unfortuantely its not freeware, but i dont think it is that expensive (cant remember off the top of me head).
Leave your comments and thoughts on the software here please, so as to make the forum tidier. 😃
SAbz
Optimum settings:
1) Under Input and Output, select the file required and the destination you wish to save the encoded file.
2) Under Encoding Profile, select 'Mobile Devices (3GPP compliant)' and click apply setting.
3) Now click the 'Image Processing' tab, and click the setup button next to 'Cropping/Resizing' and ensure that the QCIF option on the right is checked.
4) Then click the 'Video Processing' tab, select 'User Defined' under 'Target Framerate' and set it to 20Hz
5) Click back onto the 'Basic 1/0' tab and click the record button.
6) Wait about 1-10 minutes, depending on the file length and voila!
If anyone else finds they have better video or audio quality, or a smaller filesize with other settings, please let me know 😃
SAbz
Well,its not new 😉 P800 users seem to like it a lot.I tested it once or twice and it crashed a lot so a gave up 😮 Since you recommend it i'll try it again but i don't think anything can beat SmartMovie right now(Mobiclip 😉)
SAbz911 wrote:Optimum settings:
SAbz
i am using the x4 live already for a long time. i have not found anything that is better. absolutely worth getting the full version; they even lowered the price to 19 euros now ...
I'm having torouble with this software. When I record a video, although it shows the output as being longer than 10 seconds when I actually click on it after its done it finishes after 10 - 15 seconds. What have a done wrong?
Thanks for any help in advance
