Task manager?
6 replies · 1,876 views · Started 25 March 2004
I feel I ought to know the answer to this but I have looked high and low so here goes.....
Is there an app on the 6600 similar to Task Manager in Windows? I ask because I'm having trouble running Avantgo (again) and there's an app running in the background called Mobilelink which i can't switch off.
Any ideas?
Cheers
Kav
If that's the one between between the green answer key and the predictive text key on the left hand side, it brings up 4 shortcuts to various apps.........or am I missing something?
Cheers
Kav
You're missing the fact that those 4 shortcuts are the programs you have running at the time 😃
And if you go over any of them and press C then you can kill that process 😃
There is of course 3rd party software for this. There is one from Psiloc (www.psiloc.com) but I don't remember its name. And there have to be others.
You can also see running processes with AppMan from www.symbianware.com and others 😃
You're welcome, mate.
We're here to try and understand the phone too 😃
Thank you for "connecting people", Nokia 😃
I once had that commercial. That would look cool for a startup logo. The naughty "connecting people" commercial 😃
