Hi!
I use to own a nokia 3650 , until it got stolen .
I am planning to buy SE 900. Please clear my following doubts :
1. Can p900 handle all the applications of 3650
like ( Digital Image Spy, MGS games , IR Remote e.t.c.) ?
2. How is the image quality of the Photos taken in p900. Is it
better then of . nokia 3650 and 7650 .
3. What are the common bugs in p900. ?
4. Are there plenty of 3 'rd party applications available for this
Phone. ( Like multimedia applications and Games)
5. Is it very sensitive and does its touch sreen demands a lot
of care ?
That will be all . Thanks .
1.The P900 is a UIQ Symbian device,the 3650 is a Series 60 Symbian device.Series 60 apps don't work on UIQ but most of them are ported and Series 60 apps have its UIQ equvialents.
2.No,but close enough.
3.Search the forum or wait for someone else to answer.
4.Yes,try the shop: http://www.allaboutsymbian.com/shop/
5.For me it was ok,but i have only used it for a short period of time,some say its too fragile.
3: Common bugs are few and far between IMO, sometimes applications close or won't start, but this is probably due to you having loads of apps open at the same time, which can easily be closed with "switcher" or an equivelent program, or simply turning the device off and on 😊 ...it's a good lil phone, I haven't found anything to replace it with (for me yet)...only real downsides can be if your a games player, you'd be better off with a S60 device as controling driving games and such is hard work...but for other multimedia and work orientated apps it's spot on.
Whoops, forgot to answer 5:
I give my screen a lot of abuse TBH, I don't use a screen protector, I never have...I don't use a case or anything of that nature, it's usually in my pocket, whilst at work or doing other things...i've never had a problem with it, i'd say it's pretty robust...sure mine could be in better overall condition but it's all good to me 😊
