goldeen
4 replies · 1,190 views · Started 26 March 2004
new theme first one i made where a wallpaper is compatible, the sqaure and rectangle ones.
Attachments: Goldeen.jpg G1.jpg g3.jpg
i wish i could change font colors, icons and so much more customations 😞 . I only use theme editor microforum, its the only one thats fast and simple to use but not very advanced.
nokia studio izzzz soooo sloooooow like half an hour just to see a preview. 😞
i wish there was another prog out there to make 6600 themes that solve the problems of the only 2 available.
well yeah it's slow but it's just a patience thing.. it only takes me about 20 sec. for a preview.. i do get mad from time to time but in my opinion it's worth it cuz you can do more..
just had to make a few adjustments, but here it is. the writing isnt hard to see, as the screenshots make it look. once u install it its okay enjoy 😃
BTW i recommend u change the wallpaper if u like, it works well with those square wallpapers(if u know wat i mean) 😱 the background works like a frame.
Attachments: g2.jpg goldeen.sis (222 KB)
