I am using an MMC reader to transfer my files between the phone and PC. I can transfer videos, WAV files, images across no problem but I cannot get my phone to see the sis files (software) that I have put in folders. Does anyone know why this is? Thanks for your time
Nokia 6600 not finding SIS files
You will need a 3rd party file manager installed on the phone. The built in file manager will not display *.sis files.
Try Fexplorer
Try uploading the .sis files in the root of the MMC.It might work.
Paste the sis file into the root folder, then use fexploer or seleq to select it. the phones installer should then start
dD_Daz wrote:I am using an MMC reader to transfer my files between the phone and PC. I can transfer videos, WAV files, images across no problem but I cannot get my phone to see the sis files (software) that I have put in folders. Does anyone know why this is? Thanks for your time
hey did u got the solution of this problem... if yes.. then tell me.
and tell me what is root directory
[email][email protected][/email]
ravivirwani We will let u know wht ever u want but frist become a Register user and obey the rules
as posting e-mail is not alloweded.
i've had exactly the same problem, someone mentioned getting seleq, but how can you get the seleq programme onto you phone either? someone reply as this is really annoying me!!?*
