MidpUi.
8 replies · 3,516 views · Started 26 March 2004
This is very annoying!!! I access the applications menu to play on my downloaded java games and it says " app. closed MidpUi ". It all happened when i created a backup memory on my card then try to restore mem. the phone froze and then now this happened i have been to most of the phone shops and it is " i have never seen that "
Sounds like it may need a hard reset. Maybe something wasnt transfered correctly when your backed up the phone memory.
SAbz
Unregistered1 wrote:how do u hard reset an N-gage
This is what you must do to solve the problem if you get this error
toep. afgsl midpui this is what you must do *#7370 all the things on
your n-gage wil be reset then you have solve the problem for questions
[email][/email]
i'm having the same midpui problem with my n-gage.i tried hard reset but it requires me to key in lock code-the problem is, i lost the code itself....is there any other way to reset it....do you guys need to key in lock code to hard reset?plz help thx.
You need the lock code. The lock code, if you haven't changed it, is (as documented in the phone's User's Guide) 12345. If it is no longer the default, then you need to send/take the phone to your nearest authorized Nokia service center; they can solve that.
