Writing from WinXP to mmc with cardreader without formatting the card
4 replies · 2,349 views · Started 27 March 2004
How do I write files from my computer to the card, without having to format the card? Are there some software that can help my PC to read the card?
Q: when you place your MMC in the card reader, does your computer react in any way?
For example: I have an ECS card reader that was bundled with some motherboards and I had to download and install some drivers in order for it to work...
No, not really. The cardreader has created some temp. drives for the cards, and when i select the drive with the card, it says that I need to format the card.
