hi all i've just downloaded the theme editor program but i keep getting this message after i make a theme and try to save it
MAKING DESCRIPTOR FILE
SUCCESS!!
MAKING SKIN PACKAGE
C:\Program Files\Theme Studio\bin>echo off
CREATING SKIN FILES
FAILED while executing skin descriptor compiler
FAILED !!. Read report given above
What am i doing wrong to not be able to save my theme
I used to have the same trouble. But since i re-installed windows xp (not only because this progg didn't work, my system was instable) it works fine again. So it is not the best option but i think it works! :tongue: :dontknow:
remcokatz wrote:I used to have the same trouble. But since i re-installed windows xp (not only because this progg didn't work, my system was instable) it works fine again. So it is not the best option but i think it works! :tongue: :dontknow:
Can't be arsed to try that i dont see what that should cure it could someone else help me
Hey i'm just trying to help dude! And i'm very sure it works but if you don't wanna do it, it is your choice. But just like i said my system was instable and i installed some things in the wrong way.
What kinda windows have you got? And if you have got xp did you install the programm in "windows 2000 mode"?
ill try to get some more info for you,
remco katz.
Dangerous tigerbread and soup with balls!
