I am like many quite interested in this phone but there are some unresolved questions before the phone makes a proper appearance.
1. 9210 compatibility.
a. Is the 9500 able to read contact databases directly from a MMC used in a 9210?
b. What will the agreed procedure for migration to the 9500 - in particular copying of contacts, applications, message store, log.
For example Bounce.
2. Series 60 compatibility.
a. Can contacts from Series 60 phones such as the 6600 be read correctly by the 9500?
b. Will Nokia provide a the facility to run Series 60 games/applications on the 9500 (I am not on about the N-Cage) - obviously with the reduced screen display.
3. Trade in.
Are any vendors considering a price reduction if you trade in your old 9210.
4. Software reliability.
My first 9210 had many problems with crashes and reboots - are we sure that 9500 would have these same software problems in the first few months.
5. Office software.
a. Are later versions of Office being supported as well as the older versions.
b. Can the Acrobat reader handle - the newer Reader 6 format.
I have the free reader from Adobe but it is for Acrobat 5 files.
6. Other wanted changes:
a. 'log' - save the contacts to a sheet file, add date range or contact name criteria.
b. Support for larger MMC cards 128mb and above.
c. A 'firewall' application for the phone.
d. HTML and rich text email support.
e. SMTP authentication for outgoing email - now essential.
f. VPN, SSH, FTP clients as standard.
g. Voice dictation and command software that works!
h. Support for non-Unicode text on email/SMS pending on the country setup
of the phone.
This is important because of those without Nokia's who cannot read SMSs
sent to the communicator in all cases.
7. Security features.
a. I have heard about remote SMS locking - is this confirmed.
b. Now about an alarm from the phone if it is moved too far from your
bluetooth handset - determined by signal strength.
c. Password protected files and contacts as standard.
