umm... help?
3 replies · 1,648 views · Started 29 March 2004
this is an interesting one i think. Now i've searched the forum and found some answers, however none are specific to my question, so i figured i might as well ask. I have t-mobile (usa) and have t-zones. the interesting thing is, i can view other websites without a problem, but when i try to load up my personalized one (my t-zones page), using the default url that is supplied with the settings t-mobile sends, i get a blank screen. I've called t-mobile tech support, no answers there. I've looked at the web page numerous upon numerous times, no answers. Has anyone experienced similar problems (if so, help!?!?!?).
Thanks guys,
~Aniron
Well, i decided to hard reset my phone using the *#7370#. First i removed my memory card (didn't want to lose any of my files). i load everything back up and voila, it works. I put my memory card back in and for some reason it was having the same problem. I took it out again, it works. I delete everything off my memory card(of no importance like java games and the such) and now it works again. I don't know if this helps anyone, but there ya go. problem solved.
That's a strange error! No idea what caused it, but thanks for posting your solution. Hopefully it will benefit someone in the future.
Rafe
Ok, so i know that it had something to do with my memory card, but i couldn't figure out what. So i deleted everything (yes everything) off my mem card and plugged it in. Now it works. So it's not the fact that my memory card was in, it was something on the memory card. So i start re-installing things one by one with a test of the internet inbetween each installation. It still works, so i'm baffled. Ok, well, i decided to put some music back on my mem. card. Still works. I then decided to put some ringtones back on my memory card. Still works. But here is where i found the problem to be. I opened of FExplorer and copied them into my ringtone folder so that i could use my memory card and still get my ringtones to work. Guess what, it didn't work. So, what that means is that if you use FExplorer to manipulate files around on the N-gage, you will have trouble with t-zones.
That's about it.
Hope this helps even more
